Linear-roller bearings
The MX Series of linear-roller bearings offer extreme rigidity, high accuracy, and smooth motion. Four rows of cylindrical rollers provide a greater contact area and deliver a higher load capacity than slides using steel balls. An extremely rigid guide rail eliminates deformation under high loads for stable performance under fluctuating or heavy loads.
The MX Series provides damping to allow the bearings to deliver machining accuracy, high-speed cutting, and precision grinding under high vibration and shock conditions. For maintenance-free operation, a C-Lube system distributes lubricant to the loading area through the cylindrical rollers as they circulate.
IKO International Inc.
91 Walsh Dr.
Parsippany, NJ 07054
(800) 922-0337
www.ikont.co.jp/eg
