Photoelectric sensors
The FB Series M18 plastic dc photoelectric sensors are 18-mm sensors in diffuse, polarized reflective, and through-beam models with sensing distances ranging from 70 mm to 8 m. All models feature M12 quick-disconnects and are available in npn and pnp outputlogic configurations.
The PB Series of inductive dc proximity sensors come in 12 models —12, 18, and 30-mm sizes — with shielded and unshielded housings and sensing ranges of 2 to 15 mm. Fitted with M12 quick-disconnects, the nickel-plated brass sensors are IP67 rated and feature npn or pnp logic outputs.
AutomationDirect
3505 Hutchinson 3505 Hutchinson Rd.
Cumming, GA 30040
(770) 889-2858
www.automationdirect. com/sensors
