Side-exit check valve
The new 093 Lee Chek is an ultraminiature side-exit check valve. The 0.093-in.-diameter valve is based on the same technology as the 0.187-in.-diameter side-exit Lee Chek
The new 093 Lee Chek is an ultraminiature side-exit check valve. The 0.093-in.-diameter valve is based on the same technology as the 0.187-in.-diameter side-exit Lee Chek. The 0.14-gm valve offers a 90% reduction in weight over the 187 Model and is 50% shorter for a reduction in installation boss size and weight.
The all-stainless-steel valve features a hard metal-to-metal seat and is available in a forward-flow configuration.
The Lee Co.
2 Pettipaug Rd., Box 424,
Westbrook, CT 06498
(860) 399-6281
www.theleeco.com
© 2011 Penton Media, Inc.
