Modular power cables
The complete line of Brad modular power products feature rugged, molded trunk cables for feeder circuits up to 30 A, 600 Vac/dc and molded drop cables for branch power distribution circuits up to 15 A, 600 Vac/dc. The cables reduce operating costs, accelerate machine setup, and increase speed to commissioning of new industrial equipment.
Connectors are offered in two keying options for mechanically differentiated circuits on trunk and feeder lines. Tees with a crop connector provide an access point for branch circuits to field devices, while tees with a trunk connector split the main feeder circuit into subsegments.
Quick-connect connectors and cordsets support rapid field wiring. All connectors have an extended ground conductor pin, which meets the requirement for first-mate/last-break.
Molex Inc.
2222 Wellington Court
Lisle, IL 60532
(800) 786-6539
www.molex.com
