Linear positioner
The MX45S linear positioner is designed for space-restricted applications. The 45-mm-wide screw-driven positioner features anticage creep-cross roller bearings
The MX45S linear positioner is designed for space-restricted applications. The 45-mm-wide screw-driven positioner features anticage creep-cross roller bearings, which let users position up to 7 kg (15.4 lb) of normal load on the three standard travel lengths (5, 15, and 25 mm). They come with either a high-efficiency leadscrew or high-precision ball screw, both of which are capable of producing 40 N of thrust at linear velocities of 20 mm/sec and 30 mm/sec, respectively.
Available options include rotary and linear encoders, digital limit/home sensor packs, and the ability to order and receive one of 11 preengineered multiaxis systems.
Parker, Electromechanical Actuator Div.
5500 Business Park Dr.
Rohnert Park, CA 94928
(800) 358-9068
www.parkermotion.com
© 2011 Penton Media, Inc.
