Stainless isolation valves
L-O-X energy-isolation valves, cast from 316 stainless steel and with durable fluorocarbon seals, resist saltwater and chemicals and handle severe environments such as pulp and paper, off-shore, and chemical processing. The self-draining valve is also suitable for wash-down applications in the food, dairy, and beverage industries.
The valve has a tamperproof locking mechanism, large exhaust port for rapid pressure relief, and easy operation with a simple push/pull handle. Port sizes range from 0.25 to 2 in. It also has a pressure sensing port for a pop-up indicator or pressure switch to verify the release of downstream pressure. The devices help meet OSHA, ANSI, and CSA requirements.
Ross Controls
1250 Stephenson Highway
Troy, MI 48083
(800) 438-7677
