Tank-mounted filter
The MRT tank-mounted, medium-pressure filter is for hydraulic reservoirs. Its standard 18LCZ elements reportedly offer high dirt-holding capacity and beta efficiency
The MRT tank-mounted, medium-pressure filter is for hydraulic reservoirs. Its standard 18LCZ elements reportedly offer high dirt-holding capacity and beta efficiency. Optional Dirt Catcher elements help keep the oil clean during element change out. The MRT Series comes with standard 1.5-in. SAE porting and is compatible with the company’s D5 and MS10 Dirt Alarms. Cyclic pressure rating is 750 psi, for applications with high-pressure surges in the return line. The tank-mounted unit is especially suited for mobile equipment with limited space. Other applications include injection-molding and steel-manufacturing operations.
Schroeder Industries
580 West Park Rd.
Leetsdale, PA 15056
(800) 722-4810
www.schroederindustries.com
© 2011 Penton Media, Inc.
