Voltage transducer
The easy-to-install VTD Series of high-performance voltage transducers are packaged in a 35-mm-wide DIN-rail enclosure
Nov. 17, 2011
The easy-to-install VTD Series of high-performance voltage transducers are packaged in a 35-mm-wide DIN-rail enclosure. The transformer senses voltage in dc-powered installations, including industrial motors, battery chargers, photovoltaic arrays, and wind generators. They help avoid motor overheating by detecting below-normal voltage conditions, and detect voltage conditions that can stress or damage starter components.
VTD voltage transducers can be used on circuits from 0 to 15 Vdc to 0 to 600 Vdc. Fully isolated and industry-standard 4 to 20-mA loop-powered output uses existing controllers, data loggers, and SCADA equipment.
NK Technologies
3511 Charter Park Dr.
San Jose, CA 95136
(80) 959-4014
www.nktechnologies.com
© 2011 Penton Media, Inc.
