Kit measures motor-shaft voltage
The new AEGIS shaft-voltage test kit measures and documents damaging voltages induced by variable-frequency drives. The kit includes a special replaceable probe tip for highly accurate voltage readings on rotating equipment. The tip contains high-density conductive microfibers for continuous contact with a rotating motor shaft.
The kit is a collaboration between EST an d Fluke Corp. EST makes the tip and extension rod, while Fluke makes the 10:1 probe itself and the Fluke 190 Series ScopeMeter portable oscilloscope that displays the voltage waveform and saves the image for reporting.
Electro Static Technology
31 Winterbrook Rd.
Mechanic Falls, ME 04256
(866) 738-1857
www.est-aegis.com
