Rotational measurement sensors
The PMI360DV rotational measurement sensors with analog output are user configurable to provide 0 to 360° sensing of rotational position and angular measurements. The multifunction inductive-based sensors let users set the measurement range and rotation direction, pnp-output signal width, and zero position. Voltage or current output has a repeatable accuracy to 0.5° and resolution to 0.2°. LED indicators provide visual status for power, lost target, and configuration lock variables.
Pepperl+Fuchs
1600 Enterprise Pkwy.
Twinsburg, OH 44087
(330) 486-0001
www.pepperl-fuchs.us
