Dual-action head assembly for brakes
A new dual-action head assembly for the AquaMaKKs line of watercooled brakes provides both fail-safe parking and precision tension braking capability.
AquaMaKKs water-cooled brakes provide accurate torque control for constant tensioning in heavy-duty continuous-slip tension applications such as drawworks and other hoisting systems. Copper wear plates are used for heat absorption. A patent-pending water-jacket design ensures high heat absorption and torque stability.
A spring-set feature assists primary braking systems in parking and E-stops by providing additional torque during a controlled system failure and additional braking redundancy.
The dual-action head assembly can be retrofit onto existing pneumatically controlled 25 and 36-Size Aqua- MaKKs units. Spring-set and tensioning functions are either pneumatically or hydraulically operated with fewer parts for simple installation and maintenance.
Wichita Clutch USA
2800 Fisher Rd.
Wichita Falls, TX 76302
(800) 964-3262
