Linear-track system
Model 115RC linear-motion tracks accommodate a variety of applications. The system features corrosionresistant aluminum tracks and recirculating ball carriages. The system comes in two lengths — 47 and 94 in. — which can be cut to required lengths. Butting togetherModel 115RC linear-motion tracks accommodate a variety of applications. The system features corrosionresistant aluminum tracks and recirculating ball carriages multiple sections extends the track to any distance. The track can be side, flat, or vertically mounted. When flat mounted, it can be oriented with the ball carriage facing up or down. Vertical mounting is for applications needing a nonload bearing guide.
The recirculating-ball carriages can be used separately for independent movement, combined as a unit, or both methods within one track.
The tracks carry a maximum of 265 lb. Load rating is based on the type and number of carriages inserted into the track. Two carriage options are available. The stainless-steel ball carriage offers the highest load capacity, and the polymer carriage is grease-free for clean and maintenance-free operation.
Accuride International Inc.
12311 Shoemaker Ave.
Santa Fe Springs, CA 90670
(562) 903-0200
www.accuride.com
