Pneumatic Slide Tables
The Series FGXS twin bore, precision table slides use a rail-bearing system for smooth operation. Dowel holes and slots on the table surface provide accurate, repeatable workpiece mounting. Magnetic pistons and sensor mounting slots are standard. Optional sensors feature surge protection, polarity protection, LED indicators, and fast switching speeds. Slides may mount via side-tapped or end-tapped holes, or with side body through holes. The units feature 6 to 25-mm bores. Options include adjustable stroke (to 150 mm) and shock absorbers.
Fabco-Air Inc.
3716 NE 49th Ave.
Gainesville, FL 32609
(352) 373-3578
