Side-entry repair sleeve
The new C-Wrap side-entry repair sleeve, for aerospace, defense, and marine applications, delivers an environmentresistant repair to damaged primary wire with nicks, chaffed, and radial cracks.
Aug. 23, 2012
The easy-to-install device consists of the outer tubing and adhesive. The C-Wrap is small in diameter and short in length for easy installation. The repair sleeve’s wraparound design eliminates the need to unpin the connector for repair. Its environment-resistant qualities prevent galvanic corrosion and allow use in a temperature range of -65 to 150°C, all while meeting D-6201 performance requirements.
Made of a meltable adhesive and radiation cross-linked modified fluoroelastomer insulation sleeve, the C-Wrap is color-coded for proper sizing, as well as ease of use.
TE Connectivity
1050 Westlakes Dr.
Berwyn, PA 19312
(800) 522-6752
© 2012 Penton Media, Inc.
