Hose guards
Four new hose guards are available that protect hydraulic hoses used in rugged operating environments from premature failure due to wear, abrasion, and deep cuts.
The spring wire guard slides over the hose to protect the surface. The heavy-duty, corrosionresistant coiled steel wire covering resists hose kinking and distributes bending pressure over the hose length.
The spiral steel wrap provides the highest level of hydraulic hose protection for the mostsevere operating conditions. The wrap covers 80 to 100% of the hose surface depending on the application. The galvanized-steel wrap provides installation and operational flexibility, while providing maximum hose surface coverage and protection.
Nylon sleeve guard provides wear and abrasion protection and flexes freely while withstanding thousands of abrasion cycles.
Spiral poly wrap installs over existing, in-place hoses and cables and provides durable protection while consolidating multiple hoses and cables for a neater, cleaner set of connections.
Kurt Hydraulics
302 Jeffers St.
Lyman, NE 69352
(866) 257-7995
www.kurthydraulics.com
