Dual-rod-guided air cylinders
The E-Series dual-rod-guided air cylinders joins the NITRA pneumatic line for applications requiring precise alignment or that have large side loads. Interchangeable with other brands, the double-acting cylinders feature a high-quality extruded aluminum housing
The E-Series dual-rod-guided air cylinders joins the NITRA pneumatic line for applications requiring precise alignment or that have large side loads. Interchangeable with other brands, the double-acting cylinders feature a high-quality extruded aluminum housing and switch-mounting tracks, dual chromeplated stainless-steel guide rods, and bronze bushings. With a maximum operating pressure of 142 psi, the cylinders are available in eight bore sizes from 12 to 63 mm, and depending on bore size, stroke lengths from 10 to 250 mm.
AutomationDirect
3505 Hutchinson Rd.
Cumming, GA 30040
(770) 889-2858
www.automationdirect.com
© 2012 Penton Media, Inc.
