Type-4X enclosures
The Hoffman Type 4X hinged-cover polycarbonate enclosures feature light-gray polycarbonate-molded hinges for secure cover attachment and stainless-steel hinge pins for chemical and corrosion resistance.
The Hoffman Type 4X hinged-cover polycarbonate enclosures feature light-gray polycarbonate-molded hinges for secure cover attachment and stainless-steel hinge pins for chemical and corrosion resistance. The nonmetallic enclosures withstand harsh environments, are corrosion resistant, and have quick-release stainless-steel latches. A drip shield, located at the top and bottom of the enclosure, protects the gasket area from dust and water ingress when installed in either left or right-hand hinge applications. The enclosures are equipped with a molded-in padlocking feature that provides wire tie and lockout capabilities, while allowing operators to easily open the well-sealed cover.
Pentair Technical Products
2100 Hoffman Way
Anoka, MN 55303
(763) 421-2240
© 2013 Penton Media, Inc.
