Heavy-duty pneumatic cylinders
The NITRA pneumatic product line now includes D-Series heavy-duty air cylinders suitable for applications where abusive conditions are a concern.
Features & benefits
Interchangeable with common brands of NFPA cylinders
Made of high-quality aluminum components, including a magnetic piston fitted with a PTFE wear band
Magnetic piston can be used along with solid-state or reed switches for rod position sensing; cylinders are fitted with a Teflon-impregnated heavy-duty external rod bearing to ensure smooth motion and stability
Operating pressure to 250 psi; bore sizes 1.5 to 4 in.; strokes 1 to 24 in.
AutomationDirect
(770) 889-2858
automationdirect.com/air-cylinders-NFPA
