A lightweight MT 105-50-LM micromanipulator stage from Steinmeyer Inc. is for applications in semiconductor metrology, biomedical, miniature robotics, and laser industries.
• 105 × 151 mm, 25-mm height, and weight of 1.0 kg • 50-mm travel with 1-µm positional accuracy, straightness/flatness runout of ±1 µm, repeatability of ±0.2 µm • High-strength anodized aluminum, preloaded cross roller bearings, fixed stops, and incremental linear encoder with 0.1-µm resolution • XY stage version without adapter plate, or XYZ system with an optional bracket
(781) 273-6220 / steinmeyer.com
June 25, 2025
June 25, 2025
