New Products
Motors and controllers
SureStep line of NEMA 17, 23, and 34 stepping motors now includes bipolar models with 61 to 1,291 oz-in. output torque.
Features & benefits
New linear power supplies offer 32, 48, and 70 Vdc output; electronic overload protection
Drives feature resolution to 51,200 steps/rev, power to 10 A/phase; step and direction, CW/CCW pulse inputs, A/B quadrature inputs, and 12-bit analog input
Serial-communicating indexer executes motion profiles on the fly
AutomationDirect
(800) 633-0405
www.automationdirect.com/stepper-systems
Circle 160
Adjustable frequency drives
Series NFX9000 adjustable frequency ac drives provide adjustable speed control of 3-phase motors.
Features & benefits
Easy-to-understand removable keypad and features V/Hz motor control and RS485 serial communications
Quiet motor operation, high motor efficiency, smooth low-speed performance; CE compliant; hassle-free installation
Omega Engineering Inc.
(203) 359-1660
www.omega.com
Circle 161
Motion programming script
Motion Programming Script (MPS) is an easy to use, network-enabled implementation of a Basic-like programming language with commands added specifically for motion control.
Features & benefits
Makes complex motion sequences easy for anyone; short, intuitive commands
Useful in stage gantry and robotics applications; no code editor required; script accessed remotely through Telnet or Web browser
Kollmorgen
Danaher Motion Co.
(540) 633-3545
www.danaher.com/kollmorgen
Circle 162
Shaft supports
Two new 1045 carbon-steel shaft supports are available in a variety of diameters with black oxide or nickel-plated finish.
Features & benefits
Bracket-type supports in standard and long; direct mount saves space; easily installed with two bolts
Precision-cast T-shaped support provides strength and rigidity
Misumi USA Inc.
(800) 681-7475
www.misumiusa.com
Circle 162
Integration software for vision systems
Cognex Connect links In-Sight vision systems and most PLC, robot, HMI, and fieldbus systems.
Features & benefits
Simple point-and-click configuration makes it easy to control multiple vision systems from any network PC
Preconfigured drivers, templates, sample code make system setup fast
Visualization options integrate inspection images in central interface
Cognex Corp.
(877) 264-6391
www.cognex.com
Circle 163
Photoelectric sensors
Series 3130 photoelectric analog sensors feature a 10 to 100 mm sensing range, temperature stability between -25° and 55°C, and high repeat accuracy.
Features & benefits
Sensing range independent of target's color or surface structure
500-Hz bandwidth; 0 to 5 V or 10 V models; 1 to 5 or 4 to 20 mA current output
Fully potted; equipped with glass windows; IP67 compliant
Contrinex Inc.
(866) 289-2899
www.contrinex.com
Circle 164
Variable-frequency drives
VLT micro VFDs now come in an M4 frame size covering the three-phase 380 to 480 Vac, 15 to 20-hp range.
Features & benefits
Conformal-coated PCBs; serial communication via RS-485 Modbus RTU and FC protocols
Detachable control panel with or without a potentiometer
Single-phase 200 to 240 Vac, 0.25 to 2 hp; three-phase 200 to 240 Vac, 0.5 to 2 hp; and three-phase 380 to 480 Vac, 0.5 to 3 hp
Danfoss Drives
(800) 432-6367
www.danfossdrives.com
Circle 165
Clear object sensors
World-Beam QS30 clear object sensors detect targets including PET bottles and glass containers, mirrors, LCD glass with polarizing films, and semiconductor wafers.
Features & benefits
Configured by either pushbutton or remote input line
Three switching thresholds — light, medium, dark, depending on transparency
Automatic compensation algorithm adapts threshold to environment in real time; microcontroller corrects errors
Banner Engineering Corp.
(888) 373-6767
www.bannerengineering.com
Circle 166
Thermocouple interface
SCB-48×06 signal-conditioning boards let the RIO Pocket PLC interface with up to six thermocouples and RTDs.
Features & benefits
Connects directly to RIO-47120's 26-pin D-sub connector; vertically oriented from RIO connector
RIO unit contains 16 analog and 32 digital I/O, 32-bit processor, nonvolatile memory; board features arithmetic and logical processing, data logging, process-control loops, counters, timers; communicates via Ethernet and RS-232
Galil Motion Control
(800) 377-6329
www.galilmc.com
Circle 167
Inductive encoders
Exl 1100 Series rotary encoders now come in versions in which mating dimensions are the same as those of common resolvers.
Features & benefits
EnDat 2.1 interface; uses inductive scanning method, so single-turn resolution is increased to 18 bits
Position values transferred as digital information to higher-level electronics over the fast, bidirectional EnDat interface; can also be transferred as an analog signal
Integrated read-and-write EEPROM makes user parameters available in subsequent electronics
Heidenhain Corp.
(847) 490-1191
www.heidenhain.com
Circle 168
