Long-stroke gripper
PZH-plus long-stroke grippers from Schunk feature double gripping force, multi-tooth guidance, and high-strength aluminum housing.
• Monitored via magnetic-field or inductive sensors; large center bore allows installation of a camera, material feed-through, or gripping long workpieces • Four sizes; gripper weighs between 1.6 and 33 kg, has a maximum stroke/finger between 20 and 75 mm, and a gripping force between 250 and 3,800 N
(919) 572-2818 µ schunk.com
