Continuous motion silicone cables
Cicoil's highly flexible silicone cables are designed for continuous motion and harsh weather conditions.
• Suitable for windmill turbine applications; UV-resistant alternative to PVC and thermoplastic rubber jacketed cables that can be unreliable; clear silicone encapsulation is tear-resistant, needs no external armor or conduit for protection • Will not deform or wear during a lifetime of more than 10 million cycles, even under tight bending radius and constant flexing conditions • Withstand -65° to 260° C, ice, snow, salt water, acid rain, vibration, sunlight, ozone, humidity, mechanical abuse, and most chemicals • Anti-friction coating available • Flat construction allows stacking of multiple cables • Meets UL, CE, RoHS, Flame Retardant (UL 94 V-0) standards
(661) 295-1295 µ cicoil.com
