Direct-acting pneumatic valve
The Isonic V2 Series valve is a two and three-way solenoid-operated pneumatic valve.
Features & benefits
Direct-acting; flow from 0.01 to 0.05 Cv; multiple voltage and electrical connection options in both normally closed and normally open
Flow channels can be molded directly into polymer body sections, eliminating abrupt air-path changes associated with cross drilling
Ribbonlike paths create near-laminar flow with little pressure drop; push-to-connect collets allow for simple tube and manifold connections in seconds
Mead Fluid Dynamics of Bimba Co. (773) 685-6800 www.mead-usa.com
