The new AEGIS shaft-voltage test kit from Electro Static Technology (EST) measures and documents damaging voltages induced by variable-frequency drives.
• Replaceable probe tip for highly accurate voltage readings on rotating equipment; tip contains high-density conductive microfibers for continuous contact with a rotating motor shaft • A collaboration between EST and Fluke Corp. — EST makes the tip and extension rod, while Fluke makes the 10:1 probe plus the Fluke 190 Series ScopeMeter portable oscilloscope that displays the voltage waveform, and saves the image for reporting
(866) 738-1857 / est-aegis.com
June 25, 2025
June 25, 2025
