Single cylinder compressor
The 405 Series compressor is designed for OEM applications including water processing and emergency vehicles. The oilless, single-cylinder compressor features the company’s WOB-L design, stainless-steel valves, lightweight die-cast aluminum components, and a thin-wall hard-coated aluminum cylinder for maximum heat transfer. The unit comes in both ac and dc models and provides pressures of 40 psi for the ac version and 100psi for the dc.
Thomas Div.
1419 Illinois Ave.
Sheboygan, WI 53081
(920) 457-4891
