LED worklights
The stainless-steel body and clear acrylic PMMA resin lens cover of the CLK-SA LED worklights create an IP69K-rated sealed enclosure that withstands high-temperatures, high-pressure washdowns, and is resistant to water and oil. The worklights offer bright, energy-efficient lighting. The unit measures just 376 × 56 × 20.5 mm, yet outputs an ultrabright, evenly distributed daylight illuminance of 1,200 lux.
The worklights operate on 24 Vdc and consume just 12.5 W of energy. Optional M12 quick-disconnect cables allow up to five CLK-SA units to be daisy chained together.
Patlite,20130 S. Western Ave., Torrance, CA 90501, (310) 328-3222, www.patlite.com
