6W Couplings Combined with Braided Hoses
The line of 6W couplings, combined with high-pressure four and six-wire braided hose, handle applications requiring high-pressure capabilities and temperatures from –40 to 250°F. The one-piece, bite-the-wire crimp coupling with nonskive design eliminates cover skiving before assembly to the hose.
Assembly is simple and quick. The couplings eliminate leaks and in-field failures caused by shock and vibration. Available in 85 different types and popular sizes of 1¼, 1½, and 2 in., the couplings work with SAE R13 and 4SH hydraulic hose and withstand pressure to 6,000 psi.
Kurt Hydraulics, 5280 Main St. NE, Minneapolis, MN 55421, (866) 257-7995
