Low-Profile Compression Load Cells
High-speed, LC411-USBH Series USB load cells connect directly to a computer and handle 1,000 readings/sec. Free PC software makes data logging and charting of readings simple. The cells also come with .NET APIs and a command set for command line access. No additional power supply is necessary — the cell is powered directly from your computer’s USB port. The cells feature all-stainless-steel construction for harsh industrial environments.
Omega Engineering Inc., One Omega Dr., Stamford, CT 06907, (800) 826-6342
Related
Supplier Submitted
