10 YEARS AGO —
AUGUST 6, 1998
30 YEARS AGO —
AUGUST 10, 1978
Wind turbine extracts 30% more energy: A unique horizontal windturbine concept is said to extract 30% more energy from the wind than conventional types. Developed in their free time by Leo A. Hein and W. Neill Myers, engineers at Marshall Space Flight Center, the system could be located on top of a chimney to accept not only wind from any direction but also chimney updraft, which could be then fed to solar collectors. The turbine would also be less susceptible to wind damage. The sketch depicts the concept being used in a solar farm.
50 YEARS AGO —
AUGUST 17, 1958
Pocket-sized record player has no turntable and its tone arm is part of the lid. It plays any size 331/3 and 45-rpm record, is battery powered, and selfcontained with low-drain motor, transistorized amplifier, and loudspeaker. In spite of eventual battery rundown, a governor maintains constant record speed. Two rubbertipped shafts replace the usual turntable. The unit was developed by Camp Bird Ltd., London, England.3
