Stepper Motor Closes The Loop Around Tough Moves
Nov. 1, 2000
Positioning is central to a wide range of industrial applications, from the placement of electronic com-ponents on a printed-circuit board to labeling and packaging operations.
Craig Ludwick
Applications Engineering Manager
Oriental Motor
Torrance, Calif.
EDITED BY Miles Budimir
AlphaStep motors with planetary gearheads are available in six gear ratios from 5:1 to 50:1. An optional electromagnetic brake is activated to hold the position when power fails or is switched off.
A stepper motor produces maximum torque when the rotor tooth is ±1.8° from the currently energized phase of the stator.
Under normal conditions, the motor runs in openloop mode. However, if the position deviation is greater than ±1.8°, the motor switches to closed-loop mode. The position is corrected by exciting the motor windings to generate maximum torque based on the rotor position.
For short and quick moves, the AlphaStep outperforms comparable stepper motors. Because it utilizes 100% of its torque, it moves faster than an openloop stepper motor.
On a leadscrew application, a comparison of the AlphaStep with two servomotors shows that for short-distance moves, the AlphaStep outperforms the servomotors. However, for long moves, the low pole count of the servomotor provides quicker move times.
In belt and pulley applications, high compliance usually requires low gain settings and therefore long move times. In this case, the AlphaStep outperforms the servo for both short and long moves.
When it comes to position control, the choice is often between a stepper motor and a servomotor. Because stepper motors typically have more poles than servomotors, they produce a lot of torque for their size. They are also stable and provide quick and accurate moves. Moreover, the fact that they are open-loop devices means that they cost less than a comparable servomotor which requires an encoder or resolver for position feedback. On the downside, an excessive load or vibration can cause a stepper motor to lose synchronism with the input pulses and miss a step. And because there is no feedback loop, the motor has no way of compensating for the position inaccuracy.
Servomotors, on the other hand, avoid this problem by incorporating a feedback loop for position control. However, because servomotors are often unstable, they require gain control. A relatively high gain gives quick response to position deviations but often generates overshoot as well. Lowering the gain reduces overshoot but increases response time. Gain settings are therefore adjusted to strike a balance between response time and overshoot. Also, gain settings add a delay to the total move time.
But the AlphaStep motor/drive combination from Oriental Motor melds the best of both motor types. It combines the quick response and high torque of stepper motors with the feedback power of servomotors to compensate for missed steps. It uses a high pole-count stepper motor and incorporates a resolver for position feedback. A control algorithm makes corrections for position deviations on the fly and doesn't miss steps. Also, a smaller NdFeB magnet is used in place of AlNiCo because neodymnium has a much higher flux density while producing the same amount of torque.
Most stepper motor rotors have 50 teeth, with an angle between each tooth of 7.2°. The stator has eight pole pieces; four set 90° apart make up one phase and the other four make up the other phase. When phases are energized, a torque vector develops and the magnetized rotor tooth moves to align with the torque vector. A pulse input to the driver energizes some phases and deenergizes others, generating another torque vector. The rotor then moves a quarter of a tooth pitch, or 1.8°, to align with this new torque vector. The process continues as each successive pulse is input to the driver. Thus, each phase is contributing a sineshaped torque/displacement curve with a period of 7.2°. Maximum torque is produced when the rotor tooth is 1.8° to the left or right of the stable equilibrium point. This is called full stepping and it involves an eight-step electrical sequence.
Microstepping involves more torque vectors. Instead of fully energizing a phase or leaving it off, digital-to-analog converters are used so that the phases are partially on or partially off, dividing each 1.8°step into many smaller steps. Some microstepping systems are capable of a 250-step electrical sequence producing up to 125,000 steps/rev. The main advantage to microstepping is higher resolution and lower vibration.
One limitation of stepper motors is that they are designed for open-loop control. The driver is given a certain number of pulses to move the motor. However, excessive load or high vibration can cause the motor to lose synchronism with the input pulses and miss steps. A stepper motor misses steps because the rotor has to move so much that the next tooth, or some other tooth, moves to align with the torque vector. When an external force or vibration is encountered, one or several rotor teeth can be skipped in either direction. Because the torque/displacement curve is 7.2°, the rotor has to be displaced a little more than 3.6° in either direction. The rotor will then move forward or backward, losing synchronism.
For position verification, encoders can be placed on the back shaft of the motor. One problem with this is that the position is often corrected at the end of a move after the encoder counter has been compared to the input pulse counter. If the motor misses steps, a correction introduces delays and additional steps.
The AlphaStep incorporates a resolver for position feedback to compensate for missed steps. A resolver is used instead of a digital encoder primarily because it is a relatively simple construction with no internal circuitry or fragile glass masks. The variable reluctance resolver is a two-phase device.
The output consists of two sine waves 90° out of phase. By sending the sine waves through a resolver-to-digital converter, the motor position is known at all times. Once the data has been digitized, the information increments or decrements a rotor position counter. Resolvers are also more suitable for hot environments and applications with vibration. Furthermore, they are less susceptible to electrical noise and require less wiring.
As the motor steps, the input pulses and resolver counts are fed into a pulse counter and a position counter, respectively. The two are constantly compared for deviations. If there are no deviations, the motor phases are normally excited. This is called the open-loop mode. However, if any deviation greater than 1.8° is detected, the unit goes into the closed-loop mode. In the closed-loop mode, the torque vector at the 1.8° displacement is energized, producing the maximum amount of torque to bring the rotor back into synchronization. If the motor has missed several steps, each successive torque vector at the 1.8° displacement is energized, until the deviation is brought to within 1.8°. At that point, the motor returns to the open-loop mode and steps normally.
After the final step, the rotor tooth returns to align with the torque vector and the accuracy becomes +5 arc min (0.083°). The only way for the motor to miss steps is to be in the closed-loop mode for more than 5 sec. In other words, if an excessive load is encountered for more than 5 sec, the driver will fault and send out an alarm signal.
The motor also incorporates a jerklimiting filter into the driver. Jerk is the derivative of acceleration and causes vibration at velocity transitions. Limiting jerk with a filter produces smoother motion. However, adding the filter does increase move time. The ideal jerk limiting time is one cycle of the lowest resonance frequency, so it is typically around 5 to 10 msec. Therefore, the move will be that much longer, but repeatable.
The AlphaStep incorporates all of this functionality into the drive and not the pulse generator. Typical closed-loop stepper-motor systems include a complicated controller or pulse generator. The controller senses the encoder or resolver feedback and does the comparing. If the motor has missed steps, it is the function of the controller to make up the difference. It is also a function of the pulse generator to send out the pulses at a specific time to limit jerk. Because all of this is included in the AlphaStep drive, no complicated frontend system is required. Pulses can be generated by a simple pulse generator, a PLC, a computer board, or logic chips.
Production downtime caused by faulty conveyor motors leads to financial loss, so choosing the right drive system is essential. Explore industry-leading solutions engineered for...
Aug. 7, 2025
Get better products to market faster. This e-book reveals how industry leaders are adopting an agile approach to product development with integrated design and collaboration software...
Aug. 7, 2025
Change is difficult, but with the right plan, it can be successful. Learn from Rathbane Group's transition from 2D to 3D and their strategies for leveraging efficiencies and mediating...
Aug. 7, 2025
Discover how the Autodesk Platform helps you embrace a cloud-first evolution in design and manufacturing, connecting your data and unleashing your agility with AI-powered insights...
