Machine Design
  • Resources
  • Members
  • Directory
  • Webinars
  • WISE
  • CAD Models
  • Advertise
    • Search
  • 3D Printing & CAD
  • AUTOMATION & IIOT
  • Robotics
  • Motion Systems
  • Materials
  • Video
  • Data Sheets
  • Topics
    Industry Markets3D Printing & CADAutomation & IIoTFastening & JoiningMaterialsMechanical & Motion Systems Medical DesignRobotics
    Resources
    Machine Design ResourcesWISE (Workers in Science & Engineering)Company DirectorySearch Data SheetsContributeDigital Edition ArchivesCSIA Exchange
    Members
    ContentBenefitsSubscribe
    Advertise
    https://www.youtube.com/channel/UCXKEiQ9dob20rIqTA7ONfJg
    1. Archive
    Rack-And-Pinion Design Made Easy With Cymex
    Oct. 19, 2000
    Choosing the right rack-and-pinion design is time consuming and costly.
    Choosing the right rack-and-pinion design is time consuming and costly. Searching through dozens of gear reducer and motor catalogs and plugging through calculations can be tedious. Cymex (Cyber Motion Explorer) software from Alpha Gear Drives, Elk Grove Village, Ill., lets engineers size and select gear reducers and motors for rack-andpinion applications with just a few keystrokes. The software can also select parameters for ball-screw, belt-drive, and pulley-drive applications.
    Cymex calculates output-bearing life, massmoment of inertia fromseveral combinedbodies, masses of combined components, transmissionratios, rigidity, backlash, mean and max speed,mean and max torque, andprofiles of distance, speed, acceleration,and torque. The Windows-based program allows the user todefine motion characteristics, special featuresof the application, aswell as the operating requirements of the gear reducer and motor.
    For the rack-andpinion application, inputs include the mass to be moved, load angle, friction force, pinion reference circle diameter, width of pinion, material, and efficiency. The user defines the cycle as time/distance, distance/speed, or time/speed. They enter the maximum acceleration or maximum acceleration period, dwell time, and external force/angle if there is one. The software generates a table showing motion profile characteristics. Once calculated, different drive variations and applications can be stored and recalled for comparison without recalculating the original drive system.
    From there, the software helps select a proper gear reducer and motor from its database of nearly 1,400 servomotors and 600 gear reducers. Once the optimum design has been finalized, Cymex will list geometrically equivalent motors and
    automatically select the correct adapter plate and bushing. It can print out relevant data sheets, output a DXF file that can be imported into drawings, and generate orders with the correct part numbers and order codes.
    Cymex requires a PC with a 486/100-MHz processor or higher, Microsoft Windows 95, Windows NT or higher, a minimum of 42-Mbytes/8-Mbytes free hard disk space, and Internet Explorer 4.0 or higher.
    Continue Reading
    Brushed vs Brushless Motors: Which is Best for your Application?
    Q&A: Enhancing Performance and Versatility with Advanced 3D Printing Materials
    Smart Factory Solutions that Connect and Protect from Amphenol RF
    Nov. 28, 2023
    Stay Connected and In Control of Your Future Factories with Littelfuse
    Nov. 28, 2023
    Turn to NKK Switches for the Widest Range of Industrial-Savvy Electromechanical Switches
    Nov. 28, 2023
    Unlocking Operational Flexibility in Manufacturing with Industria IoT
    Nov. 28, 2023
    I already have an account
    New
    Universal Robots Unveils UR30: Relief for Heavy Lifting
    A Beginner’s Guide to Design Failure Mode and Effects Analysis (DFMEA)
    Deliver Robust Automated Systems Through Servo Maintenance
    Most Read
    For Better or For Worse, Multimodal AI Cultivates New Frontiers
    Why it’s Time to Replace Hydraulic and Pneumatic Actuators with Electric Cylinders
    Sponsored
    Capacitive Sensors
    Push-In Terminals versus Other Types of Connections
    The SMART Non-contact Safety Sensor SRF With an innovative diagnostic system
    Machine Design
    • About Us
    • Contact Us
    • Advertise
    • Do Not Sell or Share
    • Privacy & Cookie Policy
    • Terms of Service
    © 2023 Endeavor Business Media, LLC. All rights reserved.
    Endeavor Business Media Logo
