Machine Design
  • Resources
  • Members
  • Directory
  • Webinars
  • WISE
  • CAD Models
  • Advertise
    • Search
  • 3D Printing & CAD
  • AUTOMATION & IIOT
  • Robotics
  • Motion Systems
  • Materials
  • Video
  • Data Sheets
  • Topics
    Industry Markets3D Printing & CADAutomation & IIoTFastening & JoiningMaterialsMechanical & Motion Systems Medical DesignRobotics
    Resources
    Machine Design ResourcesWISE (Workers in Science & Engineering)Company DirectorySearch Data SheetsContributeDigital Edition ArchivesCSIA Exchange
    Members
    ContentBenefitsSubscribe
    Advertise
    https://www.youtube.com/channel/UCXKEiQ9dob20rIqTA7ONfJg
    1. Archive
    Flipper-type valve meets analytical needs
    April 4, 2002
    A pair of new valves from Burkert Contromatic Corp., Irvine, Calif., uses flipper actuators and flexible diaphragm materials to let them handle high pressures and low internal volumes.
    The low dead-volume, low-carryover valves eliminate cross contamination, making them well suited for analytical and medical applications. The valves (Type 6127/6128 and 6607/6608), with orifice sizes to 3 mm, can be configured as three-way valves with all three ports in the base, or as two-way, normally opened and normally closed valves. A stainless-steel plate insulates the actuator from the coil, preventing the coil from overheating. The flipper design, which is relatively frictionless and back-pressure tight, resists clogging and sticking, giving the valves a long, accurate, and reliable life. The valves maintain fast opening and closing times (15 to 25 msec) over fluid temperatures ranging from 0 to 236F. Operating fluid pressures can be as high as 42 psi on the Type 6607/6608 and up to 140 psi on the Type 6127/6128.
    Type 6127/6128 valve use ethylene propylene diene monomer (EPDM) or fluoroelastomer diaphragms to isolate fluids from metal parts, preventing metal-to-fluid contact that can cause abrasion, contamination and corrosion. Type 6607/6608 valves, on the other hand, use perfluoroelastomer diaphragms to completely separate the actuator and fluid for high purity and easy maintenance.
    Continue Reading
    A Beginner’s Guide to Design Failure Mode and Effects Analysis (DFMEA)
    How a Connected World Requires Product Adaptation and Faster Time-to-Market
    Smart Factory Solutions that Connect and Protect from Amphenol RF
    Nov. 28, 2023
    Stay Connected and In Control of Your Future Factories with Littelfuse
    Nov. 28, 2023
    Turn to NKK Switches for the Widest Range of Industrial-Savvy Electromechanical Switches
    Nov. 28, 2023
    Unlocking Operational Flexibility in Manufacturing with Industria IoT
    Nov. 28, 2023
    I already have an account
    New
    EXAIR Introduces PEEK ½ NPT Super Air Nozzle
    Using Natural Language Understanding to Power Productivity
    Intelligent Assistant Platforms Improve Conversations with Industrial Robots
    Most Read
    Universal Robots Unveils UR30: Relief for Heavy Lifting
    The Cyber-physical Training Module
    Edge Computing & Gaining Value
    Sponsored
    communication, predictive maintenance, and safety.
    Reliable and Accurate Sensing for Demanding Applications
    Industrial Automation & Process Controls
    Machine Design
    • About Us
    • Contact Us
    • Advertise
    • Do Not Sell or Share
    • Privacy & Cookie Policy
    • Terms of Service
    © 2023 Endeavor Business Media, LLC. All rights reserved.
    Endeavor Business Media Logo
