Long-lived band cylinders
The BC Series of rodless pneumatic band cylinder from Tol-O-Matic Inc., Hamel, Minn., are designed to handle tough loads in demanding envi-ronments and last a long time.
Aug. 24, 2006
The BC Series of rodless pneumatic band cylinder from Tol-O-Matic Inc., Hamel, Minn. (tolomatic.com), are designed to handle tough loads in demanding envi-ronments and last a long time. For example, all four cylinders in the BC Series use a stainless-steel band, internal air cushioning, and a rigid, extruded aluminum pole.
