Not all 60° cone fittings are created equal. And they are not always interchangeable.
Burleigh Bailey Questions often arise in regards to compatibility and interchangeability between different kinds of 60° cone fittings. Sixty-degree cone (BSPP) fittings typically serve as hose adapters on "low-cost" hydraulic systems from Asia and Europe. This is similar to how NPSM pipe swivels are typically used in the U.S. on equipment such as log splitters and other low-end hydraulic farm machinery. The two main styles of cone fittings conform to either British Standard BS 5200 or Japanese Industrial Standard JIS B8363. Both are designed as adapters rather than tube connections. And both seal by metal-to-metal line contact between the conical surface of the internal seat and a corresponding surface on the mating component. Although cone angles and threads are identical, there are instances when these fittings will not function properly if interchanged. Here is a review of the similarities, differences, and interchangeability of these two 60° cone fittings. Similarities:
Identification: There is no standard for identifying these fittings. Parker Hannifin, for example, marks JIS adapters with "JIS" on the hex or forging flats for visual identification. BS 5200 adapters do not carry a mark. Also, BS 5200 adapters may or may not have the tapered undercut. Compatibility with hose fittings: Both adapters connect to hose fittings if the connection meets the appropriate standard. Interchangeability: BS 5200 adapters do not mate with JIS swivel connections. JIS adapters might mate with BS swivels but these fittings should not be considered interchangeable because they were not designed as such. The International Standards Organization is developing a standard to replace BS 5200 and JIS, based mostly on the BS 5200 standard. In the meantime, while BS 5200 and JIS 8363 adapters are similar, in some instances they are not interchangeable. So the best advice is to avoid mixing them inappropriately. |
Comparing dimensions
size
thread
in.
in.
in.
size
thread
in.
in.
in.
Kenneth Korane
Ken Korane holds a B.S. Mechanical Engineering from The Ohio State University. In addition to serving as an editor at Machine Design until August 2015, his prior work experience includes product engineer at Parker Hannifin Corp. and mechanical design engineer at Euclid Inc.
Related
