Pipe-Joint Lubricant
The Shurjoint 550H pipe-joint lubricant is chemically compatible with FlowGuard Gold, BlazeMaster, and Corzan CPVC piping systems and has been added to the company’s FGG/BM/CZ System Compatible Program. The lubricant is recommended for proper gasket installation and helps prevent gaskets from being pinched. The tan-colored, nontoxic paste contains no petroleum and will not support bacteria. Shurjoint comes in 1-qt containers.
The Lubrizol Corp.
29400 Lakeland Blvd.
Wickliffe, OH 44092
(440) 943-4200
www.lubrizol.com
