Micro-Ball Thrust Bearings
Micro-ball thrust bearings are designed using an injection-molded, selflubricating 6/6 nylon retainer with grade 100 tolerance, hardened-steel balls, and micro-finish thrust washers for reduced noise and increased durability.
The retainer captures the balls in precision-molded pockets for smooth, free-turning operation. The bearings come in carbon and stainless steel in 4 to 12-mm ID.
Torque Transmission, 1246 High St., Fairport Harbor, OH 44077, (800) 5446642, torquetrans.com
