Color Vision Sensor
The DVT 535C entry-level color vision sensor uses Intellect software to facilitate setup, integration, and maintenance, and is backward compatible with FrameWork.
The DVT 535C entry-level color vision sensor uses Intellect software to facilitate setup, integration, and maintenance, and is backward compatible with FrameWork. The 535C is the lowest cost model in the DVT family of high-speed and high-resolution products.
Cognex Corp., One Vision Dr., Natick, MA 01760, (508) 650-3000, cognex.com
