New Products: Photoelectric Sensor
The E58 Series photoelectric sensor has a background rejection sensor with a twowire circuit design.
Extremely resistant to chemical attack, moisture intrusion, and heavy shock and vibration, the sensor’s stainlesssteel, PVDF, and tempered-glass components are mechanically assembled using FKM seals. Available with both ac and dc operation in a single unit, the sensors come in 18 and 30-mm diameters. The sensor’s visible sensing beam allows for quick setup and alignment.
Omega Engineering Inc.
One Omega Dr.
Stamford, CT 06907
(888) 556-6342
omega.com
