Reinforced PVC Hose
Vardex hose targets fluid or air transfer in applications including chemical lines, shop air supply, and water feeds and discharge.
Jan. 11, 2007
The hose is made of clear PVC with a steel-wire reinforcement completely encased in the tubing that lets the hose resist kinking, crushing, and collapse. Vardex has a mirror-smooth inner surface for maximum flow. All components are nontoxic and conform to FDA standards. The hose comes in nine sizes ranging from 0.25 to 2-in. ID. Options include special sizes, formed shapes, cut-to-length pieces, assemblies with permanently crimped-on fittings, and thermal bonding to other PVC tubing and hose.
NewAge Industries Inc., 145 James Way, Southampton, PA 18966, (800) 506-3924, newageindustries.com
