Mixed-Flow Cooling Fan
MNC cooling fans utilize a patented MF Mixed Flow Impeller with an adjustable blade geometry
for nonstall airflow properties and nonoverloading absorbed power characteristics. The medium-pressure-fans come in nine sizes and airflows to 20,000 cfm. Custom mounting arms and special designs are available to accommodate most applications. Standard NEMA motors let the fans connect to independent control systems.
Applications include electronic cabinet cooling, clean-room modules, heat exchangers, air filtration, dust collection, computer rooms, plastic extrusion refrigeration equipment, workstations, and fume hoods.
Continental Fan Mfg. Inc.,
203 Eggert Rd., Buffalo, NY 14215,
(800) 779-4021, continentalfan.com
