Belt-curve conveyor system
The system is constructed of 10-mm T-slotted aluminum. The load-bearing capacity of the system allows for direct mounting of side rails, sensors, and other accessories. The conveyor's 20-mm rolling knife edge permits gentle parts transfer from in-feed to out-feed. Standard belt curve radius is 90˚, with 180˚ available on request. Automatic belt tensioning accommodates normal belt stretch for reduced wear and a fixed installed dimension. A stainless-steel slider bed supports the Transilon belt, which is made of urethane, polyester, or PVC types with smooth woven and velvety surfaces are available; these belt types are antistatic and FDA suitable. Applications for the conveyor include medical, food, package goods, and plastics and electronics part manufacturing.
mk Automation Inc., 105 Highland Park Dr., Bloom˚eld, CT 06002, (860) 769-5500, mkprofiles.com
