Each cable has a filler twisted around four cable pairs and an internal crossweb. This increases and randomizes the distance between adjacent cables which greatly improves alien cross-talk coupling and return-loss channel characteristics. A patent-pending IDC design and patch panel-circuit layout positions each IDC at 90° to its neighbor, which cuts alien cross-talk between modules by 15 dB compared to traditional technology. The system includes an X-Bar to simplify installation and make it easy to maintain the proper conductor twist lays and prevent untwisting. A flexible circuit board within the control module lets compensation circuitry be placed at the point of plug contact to reduce delays between the cross-talk sources to reduce cross-talk at frequencies up to 625 MHz.
Belden CDT Networking Div.
793 Ft. Mill Highway
Ft. Mill, SC 29715
(800) 331-0779
www.BeldenIBDN.com
