A Nastran For NX
FEA program NX Nastran V3 now sports a hierarchical distributed memory for parallel processing to simulate large-scale dynamics.
NX Nastran V3 has enhanced Cquadr/Ctriar shell, a membrane element, that is easier to use and more versatile than previous versions.
The feature allows up to 64 simultaneous CPUs in a cluster versus the previous eight. Also, complex eigen solvers provides up to a 40% improvement over NX Nastran V1 for typical complex dynamics applications, such as brake-squeal analysis, and rotor dynamics. An advanced nonlinear module (Solution 601) is based on a nonlinear structural analysis solver from Adina. Postprocessing reduces the amount of results data that must be stored during the analysis eliminates additional postprocessing outside the system.
UGS Inc.,
5400 Legacy Dr.,
Plano, TX 75024,
ugs.com
