Long-Life Compressor
The Taskair E Series (TA-E) articulating piston unit has enclosed and permanently lubricated motor and compressor sections.
The TA-E Series provides up to 150 psi of pressure and 3.35-cfm maximum flow. The oilless units have dual cast-iron cylinders, high-strength stainless-steel valves, and PTFE piston rings and skirts, The permanent-magnet dc motor is totally enclosed, fan cooled, industrially rated, and is available in both 12 and 24-Vdc versions. The TA-E operates at 1,800 rpm.
Thomas Products Div., 1419 Illinois Ave., Sheboygan, WI 53082, (920) 457-4891, www.rtpumps.com
