-100 Degrees Cryogenic Transfer Fluid
Paratherm CR transfer fluid is an alternative to low-temperature silicone-based fluids.
100°C CRYOGENIC TRANSFER FLUID
It has a 10-cps viscosity at 88°C (20 cps at 96°C and a freezing point of 120°C. These properties reportedly make it more efficient then d-limonene fluids used in making fine chemicals. CR fluids cut process time for such production in half.
Paratherm Corp.,
1050 Colwell Rd., Conshohocken, PA 19428,
(610) 941-4900,
www.paratherm.com
