It provides excitation power for industry standard 100 mV/g (10.2 mV/(m/s2)) ICP accelerometers, and can convert the signal into velocity. Selectable low pass filters at 1k or 10k Hz, and high pass filters at 3 or 10 Hz are standard. It can also retransmit acceleration or velocity signals as a 4 to 20 mA signal for trending and simple interface with PLC, DCS, and SCADA systems. It also outputs the raw vibration signal from an accelerometer for frequency analysis and system diagnostics. It is DIN rail mounted and 24-Vdc powered.
PCB Electronics Inc., 3425 Walden Ave., Depew, NY 14043-2496, (800) 828-8840, imi-sensors.com
Sept. 16, 2025
Sept. 16, 2025
Sept. 16, 2025
