Shock-Resisting Adhesive
Two-part EP21TDCHT-1 epoxy features high peel and shear strengths, and resists vibrations, impacts, and thermal shocks.
It has a 1:1 mix ratio by weight or volume, a mixed viscosity of >150,000 cps, and bonds similar and dissimilar substrates at room temperature. It also features a service temperature range of 100 to 400°F, a 70 Shore-D hardness, and 20% elongation. It comes in 1/2 pint, pint, quart, gallon, and 5-gallon kits.
Master Bond Inc.
154 Hobart St.
Hackensack, NJ 07601
(201) 343-8983
masterbond.com
