Planetary Gearheads
Victory planetary gearheads use three or more planet gears revolving around a single pinion, or sun gear, which allows internal load sharing.
True planetary design, the manufacturer says, is optimal for moderate to high-torque factors (including radial and axial loading, weight, lubrication, operating temperature extremes, typical torque/speed load points, etc.).
CGI Inc.
3400 Arrowhead Dr.
Carson City, NV 89706
(775) 882-3422
cgimotion.com
