A new class of Explorer bearings includes spherical roller bearings, angular-contact ball bearings, cylindrical roller bearings, spherical thrust bearings, tapered-roller bearings, deep-groove ball bearings, and four-point contact ball bearings
. The products are said to last 300% longer and exceed performance normally expected with those designed to ISO tolerance specifications. The use of low-oxygen content steel and state-of-the-art manufacturing techniques prevent formation of fatigue-causing oxide inclusions, extending life and reducing fatigue failure. Ground transition raceways/shoulders handle higher thrust loads, lower overall contact stresses, and reduce edge stresses for increased power density, load rating, and safety. SKF USA Inc., 1510 Gehman Road, P.O. Box 332, Kulpsville, PA 19443(215) 513-4400 toll free 888-SKF-2000 www.skfusa.com
