Variable-Frequency AC Drives
The VariFlex Series of ac drives handle general-purpose three-phase motor-control applications
from 1 /3 to 5 hp. The front cover of the variable-frequency drive lists the 10 most commonly used drive parameters. Available frame sizes A, B, and C cover main voltages from 180 to 528 Vac, and they accept both single and three-phase supply voltages. The VariFlex Series has standard Modbus capabilities as well as a compact SmartStick that quickly clones the programming from one drive to others.
Carlo Gavazzi, 750 Hastings Lane, Buffalo Grove, IL 60089, (847) 465-6100, www.GavazziOneline.com
